Ezlo
1’’ Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
Regular price $89.95
Regular price $89.95 Sale price
1" Ball Valve Compatible with the Ezlo Water Valve
The 1" Ball Valve, compatible with the Ezlo Smart Water Shut-Off Valve, is a lead-free brass component designed for seamless integration with the Ezlo Smart Water Shut-Off System. This valve connects to the cold-water inlet of your main water line, delivering efficient and reliable control over your home's water supply.
*Ezlo Water Valve control module not included.
1" Ball Valve:
Select the right size for your pipe and integrate with your Ezlo Smart Water Shut-Off Valve.
  • Lead-Free Brass Construction: Ensures durability and safety for your household water system by complying with NSF/ANSI 61 standards, as well as California AB1953 and Vermont S.152 lead-free regulations.
  • Standard 1" NPT Fittings: Compatible with industry-standard piping, allowing for straightforward installation.
  • Manual Control Handle: Optimized for extensive residential systems or commercial buildings needing higher water throughput.
Ideal for homeowners aiming to enhance their water management system, this 1-inch Ball Valve can be installed during the plumbing phase of new constructions or retrofitted into existing systems. Its design allows for straightforward integration, providing both manual and automated control over water flow.
This ball valve is compatible with the Ezlo Water Valves
  • Model:
    EZLO-BV-1.00
  • Part Number:
    EKBVFFN100
  • Description:
    Ball Valve 510L F/F NPT 1"
    1"
  • UPC:
    850010800370
  • Reference standard:
    DIN EN 13828
  • Warranty:
    5-Year Limited
  • Documentation
    1 inch smart home ball valve shut-off
