Centralite
Centralite 3-Series Water Sensor 3315-C
Regular price $19.95
Regular price $19.95 Sale price
Protect your home from leaks and floods with the 3-Series Water Sensor 3315-C. It can detect floods and leaks before they cause extensive damage and trigger alerts. It can also be used to trigger water shutoff valves while you are away. Works seamlessly with Ezlo Plus hubs, the MiOS platform, MeshBots automation, and other compatible third-party Zigbee hubs.
*Requires an Ezlo hub.
The Centralite 3-Series Water Sensor 3315-C detects leaks and floods in your home. It uses a CR-2 battery and works with Zigbee Home Automation 1.2. Fully compatible with Ezlo Plus hubs, enabling powerful automation through the MiOS platform and MeshBots. Also compatible with other third-party Zigbee hubs.
  • Leak and Flood Detection: The Water Sensor detects floods and leaks in the home.
  • Zigbee Connectivity: Works with Zigbee Home Automation 1.2.
  • Ezlo Hub Compatibility: Seamlessly integrates with Ezlo Plus hubs.
  • MiOS Platform Integration: Enables advanced automation and control through the MiOS platform.
  • MeshBots Automation: Supports MeshBots for customizable automation scenarios.
  • Third-Party Zigbee Compatibility: Compatible with other third-party Zigbee hubs.
  • Battery Powered: Uses a CR-2 battery.
  • Model:
    3315-C
  • Battery:
    CR-2 1x
  • Protocol:
  • Compatibility:
    Ezlo Plus, MiOS platform, MeshBots, compatible third-party Zigbee hubs
