The Heart of Your Smart Home
Seamlessly connect and control all your smart devices with ease.
Ezlo
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
Regular price $149.95
Regular price $149.95 Sale price
Documents
Transform your living space into a modern smart home with the Ezlo Plus Smart Home Z-Wave & Zigbee Hub. This powerful smart home hub supports Z-Wave and Zigbee protocols, making it the ideal solution for all your smart devices. Whether you’re looking for a Z-Wave hub to control lights, thermostats and locks or a Zigbee smart home hub for sensors and switches, the Ezlo Plus has your use case covered.
Control all your Zigbee and Z-Wave devices effortlessly through the intuitive MiOS app, making your smart home both efficient and future-proof.
Powered by the advanced Z-Wave 700 series chip, the Ezlo Plus delivers faster communication, wider signal range, and superior energy efficiency. With full S2 Security support, it ensures encrypted, secure connections across your entire smart ecosystem.
Smart. Secure. Easy
Upgrade and experience seamless home automation
Connectivity with Multiple Radio Frequencies and Devices
The Ezlo Plus smart home hub gives users unparalleled control over their smart home environment and provides extensive compatibility with a vast ecosystem of smart home devices. This includes thousands of the newest and older Z-Wave and Zigbee smart devices—such as lights, thermostats, door locks, sensors, and shades, motion sensors, door/window sensors, and leak detectors—including Centralite’s trusted sensor lineup.— which ensures maximum flexibility and choice for users as they build and expand their smart home ecosystem. With MiOS automation, it becomes a powerful self-monitored safety system, delivering real-time alerts and smart automation—no monthly fees required.
Effortless Device Control
Take control of your devices using the MiOS App and two convenient methods: Local Management provides swift and direct control for immediate actions, while Cloud-Based Management offers the freedom to access and manage your devices from anywhere, anytime, through a secure internet connection.With the newly redesigned MiOS Dashboard. Enjoy enhanced filtering, quick access to key devices, and a streamlined interface built for property managers and power users alike.
Voice Control
Use your favorite voice assistants like Amazon Alexa, Siri Shortcuts, and Google Assistant to easily manage your smart home and experience the convenience of hands-free control.
Seamless Automation with MeshBots
Ezlo's automation command feature, MeshBots, allows you to effortlessly orchestrate interactions between cloud services, local devices, and applications. Ezlo Secure prioritises local execution of these automations whenever possible, minimizing reliance on the cloud and enhancing performance.
Set the AC to 72 degrees
Close all the shades
Lock the doors
Arm the security
First-Class Human Support, Always Free With Ezlo, you're never alone. Enjoy unlimited access to our world-class customer care team—real people, ready to help you get the most out of your smart home experience, at no extra cost.
Ezlo Plus smart home Z-Wave ZigBee hub
Ezlo Plus Smart
Home Hub
    4.17 x 4.12 x 1.45 in
    (106 x 104.66 x 36.95 mm)
  • RAM Memory:
    DDR3 512MB
  • Network:
    Ethernet, Wi-Fi.
    LAN Port: 10/100 Ethernet port with RJ45 connector
    Support Standards: 802.11g/n/ac Dual Band WiFi 2.4 & 5GHz
    Input: AC 100-240VAC, 50-60Hz Output: DC 5V/2A
  • Flash memory:
    Parallel NAND Flash EMMC 4GB
  • Zigbee Module:
    Zigbee 3.0 Internal Antenna
  • CPU:
    Quad-Core Cortex-A7 ARM CPU
  • Certification:
    FCC, UL, CE, RoHS, Z-Wave Plus, Zigbee, Wi-Fi
