Transform Your Home's Comfort and Efficiency
Managing your home's climate has never been easier
THERMOSTATS
Ezlo Z-Wave Thermostat
Regular price $149.95
Regular price $149.95 Sale price
Documents
Experience the perfect fusion of technology and comfort with the Ezlo Thermostat. Seamlessly integrating Z-Wave connectivity, a sleek user interface, and precise temperature control, our thermostat empowers you to modernize your home's heating and cooling system effortlessly. Create custom schedules, adjust settings remotely, and even receive alerts if temperatures fall outside of your desired range*
Upgrade Today and Experience the Difference
*All automation, remote access, and app-based configuration require pairing with a Z-Wave hub (ideally Ezlo Plus)
Smart. Convenient. Efficient
Z-Wave Connectivity
Works with Your HVAC System
Comprehensive compatibility with your existing HVAC system, allowing you to seamlessly control both heat pumps and traditional AC units. It is equipped to handle modern heating and cooling setups, supporting up to 2 distinct stages for heating and cooling.
Touch Sensitive Controls
The smooth, touch responsive surface allows for precise input and quick adjustments, making it easy to access your features and settings providing a modern and convenient user experience, eliminating the need for physical buttons and dials.
Child-Safe Mode for Peace of Mind
The Ezlo Thermostat includes a child-lock feature that prevents accidental or unwanted changes to temperature settings—keeping your home environment stable and your settings secure. Perfect for families with curious little ones!
Advanced Automation with Ezlo Hub and MiOS App
Fully compatible with the Ezlo Plus smart hub and the MiOS app, the Ezlo Thermostat integrates seamlessly with other smart devices—like temperature and humidity sensors—to enable advanced home automation. Easily control temperature, create schedules, monitor energy use, and receive real-time alerts. With remote access through the MiOS app, you can adjust settings anytime for maximum comfort and energy efficiency.
Broad System Compatibility for Flexible Installation
The Ezlo Thermostat is engineered for versatility, supporting a wide range of HVAC systems found in modern homes:
  • 1- and 2-Stage Conventional Heating/Cooling Systems
  • Heat Pumps — with or without auxiliary heat, single or dual transformers
  • Gas Boilers, Electric Heat, Hydronic Systems, and more
  • Uses Z-Wave radio frequency and connects with other Z-Wave devices
Control your home's climate and save energy with the Ezlo Z-Wave Thermostat. Get yours today and experience smart home comfort.
$129.95
  • System Compatibility:
    Controls up to 3 stages heating and 2 stages cooling
    8 types control systems
    EM heat activation
    Adjustable compressor delay time
    O/B changeover
    Applies for regular AC or heat pump systems (gas/fuel boiler, electric heating, water heating)
    Requires a compatible Z-Wave hub for remote control capabilities
  • Display & Controls:
    Frameless Display
    Touch button operation
  • Wiring:
    Wiring for Conventional Systems and Heat Pump Systems
    Various wiring configurations for different stages and setups (single and double transformers)
  • Compliance:
    CE Declaration of Conformity (Directive 2014/53/EU)
    WEEE Directive Compliance
  • Power Supply:
    AC/DC 24V
    4 "AAA" dry batteries (low power working state)
    Power input range: 20-28VAC
  • Technical Parameters:
    Self-Consumption: <1W
    Resistive Load: <1A
    Temperature Setting Range: 0~40°C (32~99°F)
    Precision: 0.1°C (1°F)
    Outcase: PC+ABS
    Wire Connection: Terminal
    Dimension: 11311319mm
    Installation: 60.3mm hole pitch
  • Functions & Settings:
    Setpoint Setting
    Mode Setting (OFF, HEAT, COOL, AUTO, AUX/emergency heating)
    Fan Mode & Schedule Setting (Fan On, Fan Auto)
    Standby & Backlight Brightness Setting
    Schedule Function (can be enabled/disabled)
    Secret Menu for advanced settings
  • Connectivity:
    Z-Wave 800 series
    Z-Wave frequency defined by regulatory bodies (for Z-wave in Europe: 868.0-868.6 MHz, 869.7-870.0 MHz)
    Support S2 function
    Z-Wave Plus compatible
Ezlo Z-Wave Thermostat - Smart Programmable Climate Control
