The Centralite 3 Series Micro Motion Sensor Indoor Smart motion sensor detects movement in a certain area to trigger lighting scenes, HVAC settings, and security alarms. The Indoor Motion Sensor measures less than two inches wide and about an inch thick. The 3-Series Smart Micro Motion Detector can be installed on a wall corner, or placed directly on a counter or table.
Key Features of Micro Motion Sensor:
Compact Design: Measuring less than two inches wide and about an inch thick, this micro motion sensor is discreet and fits seamlessly into any home decor.
Versatile Placement: Can be installed on a wall corner or placed directly on a counter or table for flexible use.
Smart Home Integration: Easily integrates with your smart home system to automate lighting, HVAC settings, and security alarms based on detected motion.
Accurate Motion Detection: Provides reliable and precise motion detection to enhance home security and automation.
Easy Installation: Simple to set up and configure, making it a hassle-free addition to your home automation setup.
Energy Efficient: Helps save energy by adjusting lighting and HVAC settings based on occupancy.
The Centralite motion sensor is part of the 3-Series and is engineered to offer reliable and accurate motion detection. By integrating this sensor into your smart home system, you can automate various tasks and create a more efficient and secure living environment. For instance, you can set the sensor to turn on lights when motion is detected, adjust your thermostat settings based on occupancy, or trigger alarms if unexpected movement is detected.
With its sleek design and advanced capabilities, the Centralite Micro Motion Sensor is an essential addition to any smart home setup. Enhance your home automation and security with this versatile and effective motion sensor.
