Ezlo
1¼“ Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
Regular price $149.95
Regular price $149.95 Sale price
1¼“ Ball Valve Compatible with the Ezlo Water Valve
The 1¼“ Ball Valve, compatible with the Ezlo Smart Water Shut-Off Valve, is a lead-free brass component designed for seamless integration with the Ezlo Smart Water Shut-Off System. This valve connects to the cold-water inlet of your main water line, delivering efficient and reliable control over your home's water supply.
*Ezlo Water Valve control module not included.
1¼“ Ball Valve:
Select the right size for your pipe and integrate with your Ezlo Smart Water Shut-Off Valve.
  • Lead-Free Brass Construction: Ensures durability and safety for your household water system by complying with NSF/ANSI 61 standards, as well as California AB1953 and Vermont S.152 lead-free regulations.
  • Standard 1" NPT Fittings: Compatible with industry-standard piping, allowing for straightforward installation.
  • Manual Control Handle: Optimized for extensive residential systems or commercial buildings needing higher water throughput.
Ideal for residential settings, this 1¼" Ball Valve is perfect for managing water flow in various applications, including main water lines, irrigation systems, and other household water control needs.
This ball valve is compatible with the Ezlo Water Valves
  • Model:
    EZLO-BV-1.25
  • Part Number:
    EKBVFFN125
  • Description:
    Ball Valve 510L F/F NPT 1¼“
    1¼“
  • UPC:
    850010800387
  • Reference standard:
    DIN EN 13828
  • Warranty:
    5-Year Limited
  • Documentation
