3/4" Ball Valve Compatible with the Ezlo Water Valve
*Ezlo Water Valve control module not included.
3/4" Ball Valve:
Select the right size for your pipe and integrate with your Ezlo Smart Water Shut-Off Valve.
This 3/4" Ball Valve is designed for use with the Ezlo Smart Water Shut-Off Valve System. During the plumbing phase of new construction, the valve is installed on the cold-water inlet. The smart actuator and control module can then be added during the trim-out phase, making installation easier and more efficient for builders.
Consider the , which includes the valve, an Ezlo Plus smart hub, and leak sensors for comprehensive water protection.
This ball valve is compatible with the Ezlo Water Valves
- Choosing a selection results in a full page refresh.
- Opens in a new window.
Your Cart
Free shipping on Ezlo and Centralite orders above $100!
