The Sensative Strips Guard 800 Door/Window Sensor is the perfect solution for protecting your home or business. This innovative sensor is designed to seamlessly integrate with your existing security system and can be easily installed on any door or window. The sensor is highly sensitive and will immediately detect any attempt to open or break the door or window, triggering an alarm and notifying you of the suspicious activity.
The sleek and discreet design of the sensor ensures that it blends in seamlessly with your home or office decor. The retail package includes everything you need to get started, making installation a breeze. With the Sensative Strips Guard 800 Door/Window Sensor, you can have peace of mind knowing that your property is being protected 24/7.
Manufacturer Part #:
11010321
UPC:
7350088520741
Frequency:
915 MHz
Z-Wave Version:
800 Series
Z-Wave Security:
S2 and Secure Vault
Z-Wave Functionality:
Smart Start
Features:
Open/Close Object Status Report Tamper Alert LED Indicator
Z-Wave Notifications:
Binary Notification Basic Reporting Types
Sensor Type:
Magnetic contact
Power Supply:
Built-in non-rechargeable battery (LiMn02), 1.4 Wh (480 mA @ 3V)
Operating Temperature:
-4 to 140°F (-20 to 60°C)
Ratings and Certifications:
IP65
Dimensions (LxWxD):
7.67 L x 0.59 W x 0.12 D mm (195 L x 15 W x 3 D mm)
