Smart Fortrezz Flood Temperature Sensor Z-Wave Plus
(3.00)2 Reviews
Out of Stock
$49.95 $39.95
(-20%)
This Fortrezz Flood Temperature Sensor alerts you when it gets wet. Just simply place on the floor near water using appliances and fixtures such as dishwashers, toilets, and washing machines. Water damage is caused by leaking pipes, corroded water heaters, leaky toilets, fixtures in bathrooms, laundry rooms with aging appliances, and more.
The Water Leak Detector is a Z-WavePlus-enabled device. Pair to your SmartHome network and receive alerts to your phone when Water Leak leaks are detected Ezlo Secure controller. Sensors work with our Water Shut-off Valve to prevent water damage from leaks by detecting the leak first, then turning off the water supply to the house, preventing any further leak. To know more about Fortrezz Flood Temperature Sensor.
Additional information
Weight 1.0009 lbs
Customers Reviews
(2)
  1. Joaquin (verified owner)
    I have had terrible experiences with 2 of these Fortrezz water sensors. The contacts are high inside the plastic body and are very unreliable. I even tried to modify one to make the water more accessible to the contacts. I finally just thruw them away. I am not willing to take a chance.
    1 product
  2. Phoenix (verified owner)
    Good service.
    1 product
• Datasheet Pdf
Back to Top
chatsimple
