Zigbee Water Leakage Sensor Alarm Water Level Detector Flood Leakage Sensor Ewelink APP Remote Control Security Alarm System
Regular price $7.94
Regular price $0.00 $7.94 Sale price
Zigbee Water Leakage Sensor Alarm Water Level Detector Flood Leakage Sensor eWeLink APP Remote Control Security Alarm System
About this item
【High Sensitivity】This water leak detector is equipped with 2 sensitive leak probes to detect water leaks and floods; detects a minimum water level of 0.5mm, providing an early warning of water damage with the LED flashing red.
【Real-Time Notifications】No matter where you are, receive timely alarm notifications in the eWeLink APP app to protect your home. ( Zigbee Gateway is required and sold separately, gateway requires 2.4 GHz internet,not 5GHz )
【eWeLink Zigbee network protocol 】 Compared to Wi-Fi, the Zigbee gateway signal is more stable and the response speed is faster, safer and more reliable. Other sub-devices can be connected, such as door sensors, temperature and humidity sensors, etc.
【Home automation 】 The device can be linked with other Tuya solution devices (WiFi devices and Bluetooth devices (gateway required) and ZigBee devices). For example, set a linking scene:If water leaks from the washing machine, the smart plug connected to the washing machine switches off automatically. Szkoston
【IP66 Waterproof】The IP66 waterproof rating and rust-resistant outer coating allow for extended use in humidity areas, such as near common household water sources like dishwashers, water heaters or washing machines.
【Easy Install】This water leakage detector does not require any installation tools,with a small size, just place it in the place where the water leakage needs to be detected, and it will be able to detect the leakage sensitively.
Regular price $7.94
