Yale Z-Wave Plus Assure Touchscreen Keypad Lever Lock, Polished Brass
Regular price $249.99
Regular price $249.99 Sale price
Shop Yale Z-Wave Plus Assure Touchscreen Keypad Lever Lock
The Yale Z-Wave Plus Assure Touchscreen Keypad Lever Lock in Polished Brass is a sophisticated and secure solution for modern homes. This Yale Touchscreen Lock replaces your existing lever or knob, allowing you to unlock and lock your door using a backlit touchscreen keypad, eliminating the need to carry keys.
  • Keyless Entry: Create unique entry codes for friends and family, removing codes as needed.
  • Z-Wave Plus Technology: Integrates seamlessly into compatible home automation systems, enabling remote access and control
  • Auto-Lock Function: Ensures your door always locks behind you for enhanced security.
  • Battery Backup: Features a 9V battery backup charger on the keypad and includes two physical keys to prevent lockouts.
Ideal for side entry doors, garage entry, basement doors, and home offices—any door with a single-hole prep. The Keypad Lever Lock is Grade 2 certified and backed by Yale, a trusted name in the lock industry since 1840, ensuring your home and family are always safe.
By integrating this lock into your home automation system, you can lock and unlock your door, create pin codes, view access history, and receive notifications from anywhere, enhancing both security and convenience.
Upgrade your home security with the Yale Z-Wave Plus Assure Touchscreen Keypad Lever Lock and experience the convenience of keyless entry combined with the reliability of Yale's trusted craftsmanship.
Face Bore 2 1/8"
Edge Bore 1"
Backset 2 3/8" or 2 3/4" (adjustable latch)
Door Thickness 1 3/8" or 1 3/4"
Strike 1 1/8" x 2 3/4"
Strike Front Round Corner
Keyway KW-1 5 Pin
Batteries 4 AA Alkaline Batteries (Included)
Handing Reversible
Grade Tested to: ANSI/BHMA Grade 2
