weBoost Home 4G Cellular Signal Booster Kit, Small-Size Home
Regular price $399.99
Regular price $399.99 Sale price
Shop weBoost Home 4G Cellular Signal Booster Kit
Enhance your cellular signal strength with the weBoost Home 4G Cellular Signal Booster Kit, designed specifically for small-sized homes. This 4G Cellular Signal Booster Kit amplifies and enhances your 4G cellular signal, ensuring faster data speeds, clearer calls, and improved overall coverage. Say goodbye to weak signals and hello to reliable connectivity throughout your home.
Key Features:
  • Superior Signal Amplification: The weBoost Home Signal Booster provides robust amplification to enhance your 4G LTE signal, ensuring seamless connectivity and reducing dropped calls.
  • Comprehensive Kit: The weBoost Signal Booster Kit includes everything you need: a powerful amplifier, an indoor antenna, an outdoor antenna, and all necessary cables for easy installation.
  • Sleek Design: With its sleek and unobtrusive design, the weBoost Home Signal Booster blends seamlessly with your home decor without detracting from the aesthetics.
  • Easy Installation: Designed for quick and hassle-free installation, you can set up the Home 4G Signal Booster in just minutes and start enjoying improved cellular connectivity immediately.
Whether you're working from home, streaming videos, or making important calls, the weBoost Home 4G Cellular Signal Booster Kit ensures you stay connected. Its powerful amplifier and antennas work together to deliver stronger and more reliable cellular signals throughout your home.
Manufacturer Part #: 472120
UPC: 810005961493
Frequencies - Band 12/17: 700 MHz
Frequencies - Band 13: 700 MHz
Frequencies - Band 5: 850 MHz
Frequencies - Band 4: 1700/2100 MHz
Frequencies - Band 2: 1900 MHz
Max Gain: 60 dB
Impedance: 75 Ohms
Connectors: SMA Female / F-Female
Dimensions: 6 x 4.25 x 1.25 inches
Weight: 0.445 lbs
Certifications: FCC
Warranty: 2 Years
