1.The zigbee fingerbot plus must be used with tuya zigbee gateway. 2.Tool cannot be used alone. It need to be used with zigbee fingerbot plus. 3.ZigBee version Work with Home Assistant Zigbee2MQTT and ZHA.(Z2M description:1 gang switch)
HIGHLIGHT
【Tpye-C Rechargeable】:You can charge directly through Tpye-C without replacing the battery, which is more energy-efficient and environmentally friendly 【New upgrade ZigBee version】:Tuya ZigBee Gateway/Hub is required 【Mini BodyDesigned】34.5*34.5*34.5mm mini body, which is working with most of product.It is not only small, but also powerful. it can be used for most of home appliances and lighting. 【APP Remote Control】Download smart life /Tuya smart APP on your phone&Tablet to control the switch anywhere/anytime. 【Hand Free Voice Control】 Compatible with Yandex Alice amazon alexa echo ,google home ect ,a simply command to voice control the receiver. 【Touch Control】 You can control it directly with your fingers. 【Group-Control Function】Multi switch in different room can set in a group ,realize group control function. 【Linkage Function】It can linkage with other switch module ,sensor and appliance in your home ,make create different scene possible,such as sleeping mode,working mode,dinner mode ,back home mode ect. 【Timer,Schedule&Count Down Function】You can create schedule according to your personal requirement ,as well as timing and count down,smart and DIY your daily life to the maximum extend. 【Family Share Function】You can share the switch to your family with the limited right,create a smart home together with your family member. 【Ultra-long battery life】:Low battery consumption, which has ultra-long battery life. 【Convenient installation】:Stick 3M glue on the bottom surface of the finger robot, paste it in the required position, open the mobile phone APP for configuration and use. 【Easy to Install】The micro switch module can be easily installed on the switch or on the wall. 【 Programmable】
Product Name: Fingerbot Plus Dimensions: 34.5*34.5*34.5mm Weight: 38g Rechargeable: Tpye-C Torque: 2.0 kgf.cm Maximum arm movement: 12mm Wireless Protocol: Zigbee 3.0 Working Temperature: -10℃-45℃ Zigbee Fingerbot: Required Gateway Hub
