1.The zigbee fingerbot plus must be used with tuya zigbee gateway. 2.Tool cannot be used alone. It need to be used with zigbee fingerbot plus. 3.ZigBee version Work with Home Assistant Zigbee2MQTT and ZHA.(Z2M description:1 gang switch) 4.Please use a 5V 1A charging cable to charge the Fingerbot
HIGHLIGHT
ć5V 1A Type-C RechargeablećPlease use a 5V 1A charging cable to charge the Fingerbot
ćType-C Rechargeableć:You can charge directly through Type-C without replacing the battery, which is more energy-efficient and environmentally friendly ćNew upgrade ZigBee versionć:Tuya ZigBee Gateway/Hub is required ćMini BodyDesignedć34.5*34.5*34.5mm mini body, which is working with most of product.It is not only small, but also powerful. it can be used for most of home appliances and lighting. ćAPP Remote ControlćDownload smart life /Tuya smart APP on your phone&Tablet to control the switch anywhere/anytime. ćHand Free Voice Controlć Compatible with Yandex Alice amazon alexa echo ,google home ect ,a simply command to voice control the receiver. ćTouch Controlć You can control it directly with your fingers. ćGroup-Control FunctionćMulti switch in different room can set in a group ,realize group control function. ćLinkage FunctionćIt can linkage with other switch module ,sensor and appliance in your home ,make create different scene possible,such as sleeping mode,working mode,dinner mode ,back home mode ect. ćTimer,Schedule&Count Down FunctionćYou can create schedule according to your personal requirement ,as well as timing and count down,smart and DIY your daily life to the maximum extend. ćFamily Share FunctionćYou can share the switch to your family with the limited right,create a smart home together with your family member. ćUltra-long battery lifeć:Low battery consumption, which has ultra-long battery life. ćConvenient installationć:Stick 3M glue on the bottom surface of the finger robot, paste it in the required position, open the mobile phone APP for configuration and use. ćEasy to InstallćThe micro switch module can be easily installed on the switch or on the wall. ć Programmableć
Product Name: Fingerbot Plus Dimensions: 34.5*34.5*34.5mm Weight: 38g Rechargeable: Type-C Torque: 2.0 kgf.cm Maximum arm movement: 12mm Wireless Protocol: Zigbee 3.0 Working Temperature: -10ā-45ā Zigbee Fingerbot: Required Gateway Hub
