Experience top-of-the-line security with the Speco 8-Channel 4K H.265 NVR with PoE, Facial Recognition and Smart Analytics, 4TB. This high-performance NVR is designed to provide you with the ultimate surveillance solution. With support for up to 8 channels, you can connect multiple cameras to the NVR and monitor your property from multiple angles.
The NVR supports 4K resolution, which ensures that you get crystal clear video footage that captures every detail. It also features H.265 compression, which reduces the amount of data required for storage and transmission, allowing you to save more footage on the included 4TB hard drive.
The facial recognition and smart analytics features of the NVR make it easy to identify individuals in the footage. You can set up custom alerts to notify you when specific faces are detected, making it easy to keep track of who enters and leaves your property.
The PoE (Power over Ethernet) feature eliminates the need for additional power cables, simplifying installation and reducing clutter. The NVR also comes with a variety of connectivity options, including HDMI, VGA, and USB, allowing you to easily connect it to your display and other devices.
Overall, the Speco 8-Channel 4K H.265 NVR with PoE, Facial Recognition and Smart Analytics, 4TB is a powerful surveillance solution that provides you with the peace of mind you need to keep your property safe and secure.
