Shop Speco 4K H.265 8 Channel Wall Mount NVR with 8 Built-in PoE Ports, 6TB
The Speco 4K H.265 8-Channel Wall Mount NVR offers a cutting-edge solution for modern video surveillance needs. Built to deliver high-definition video at 4K resolution, this PoE Network Video Recorder is equipped with 6TB of storage and supports smart analytics to optimize security operations. Ideal for both residential and commercial settings, this 8-Channel PoE NVR System allows you to effortlessly manage up to 8 cameras while benefiting from efficient video compression, smart features, and easy integration.
With 8 built-in Power over Ethernet (PoE) ports, the Speco 4K NVR simplifies your setup by allowing you to run both power and data through a single Ethernet cable. This feature not only reduces wiring clutter but also streamlines the installation process, making it an efficient solution for expanding or upgrading your surveillance system. The H.265 compression technology ensures that the video quality remains high while minimizing the impact on your network and storage capacity.
Key Features:
4K Ultra HD Resolution: Capture every detail with crisp, high-definition video. The 4K resolution is perfect for scenarios where accuracy is essential, such as facial recognition or vehicle identification.
8 Channel PoE NVR System: Connect up to 8 IP cameras with ease, thanks to the PoE Network Video Recorder's built-in PoE ports. This setup significantly reduces installation time and cost.
Smart Analytics: The Smart Analytics NVR 4K feature enhances surveillance by enabling advanced event detection, including motion detection, line crossing, perimeter intrusions, and more. This AI-powered functionality improves situational awareness and response.
Efficient H.265 Video Compression: The H.265 compression reduces bandwidth and storage usage without sacrificing video quality, ensuring optimal system performance and reduced costs.
6TB Storage Capacity: With 6TB of storage, this NVR provides plenty of space for storing 4K video footage. This ensures continuous recording over extended periods without needing additional storage solutions.
User-Friendly Interface: The intuitive interface allows for simple configuration and operation, making it easy to monitor, playback, and manage your surveillance system remotely via mobile or desktop devices.
Usage:
This Speco 4K H.265 8-Channel Wall Mount NVR is perfect for a wide range of surveillance applications. Whether you're monitoring a building's perimeter, tracking activity in parking lots, or overseeing business entrances, this PoE Network Video Recorder offers reliable performance in both day and night conditions. The 8-Channel PoE NVR System is perfect for expanding as your surveillance needs grow, providing scalability for future camera installations.
Benefits:
Superior Video Quality: With 4K resolution, the PoE Network Video Recorder ensures every detail is captured in high-definition, giving you the clarity needed for effective surveillance.
Simplified Installation and Expansion: The 8 Channel PoE NVR System and integrated PoE ports make setup and system expansion easy, reducing the complexity of installation.
Advanced Security Features: Thanks to smart analytics, the Smart Analytics NVR 4K feature enables real-time alerts for suspicious activity, helping you quickly respond to potential threats.
Efficient Storage Management: With 6TB of storage and H.265 compression, this system minimizes bandwidth usage and provides ample storage for long-term video retention.
Easy Integration and Use: Seamlessly integrate this NVR into your existing security setup and easily access footage from any device with its user-friendly interface.
