Introducing the Speco 4-Channel 4K H.265 NDAA Compliant NVR with PoE and 1 SATA, 8TB - a high-performance network video recorder that seamlessly integrates with your surveillance system. With support for up to four IP cameras, this NVR delivers crystal-clear 4K video footage at an impressive frame rate of 30 frames per second. Its H.265 compression technology ensures that the video files are smaller in size without compromising on the quality, which results in reduced storage requirements and faster data transfer speeds.
Furthermore, this NVR is NDAA-compliant, which means that it adheres to the strict security standards set by the US government. It features Power over Ethernet (PoE) technology, which simplifies the installation process by allowing both power and data to be transmitted over a single Ethernet cable. The 8TB hard drive capacity provides ample storage space for continuous video recording, and the 1 SATA interface lets you expand the storage further if needed.
The Speco 4-Channel 4K H.265 NDAA Compliant NVR with PoE and 1 SATA, 8TB is designed to meet the demands of modern surveillance systems, and its user-friendly interface makes it easy to operate. Whether you're a security professional or a homeowner looking to enhance the safety of your property, this NVR is an ideal choice for all your surveillance needs.
