The Speco 4-Channel 4K H.265 NDAA Compliant NVR with PoE and 1 SATA, 12TB is the ultimate solution for your surveillance needs. This high-tech device boasts a 4-channel capacity and supports 4K resolution for superior video quality. It also features H.265 compression technology, which drastically reduces bandwidth and storage requirements.
The NVR is NDAA compliant, meaning it meets the standards set by the National Defense Authorization Act. This ensures that your data is safe and secure. Additionally, the NVR has Power over Ethernet (PoE) capabilities, allowing you to power and connect your cameras with a single cable.
With 1 SATA port and an impressive 12TB of storage, you can store hours upon hours of footage before needing to transfer or delete data. The NVR also has remote access capabilities, allowing you to view your footage from anywhere in the world through your smartphone or computer.
Overall, the Speco 4-Channel 4K H.265 NDAA Compliant NVR with PoE and 1 SATA, 12TB is an excellent investment for any business or homeowner looking for a reliable and high-performing surveillance system.
