Speco 2MP H.265 IP Dome Camera with IR, 2.8mm fixed lens, White
Regular price $110.95
Regular price $110.95 Sale price
Shop Speco 2MP H.265 IP White Dome Camera With IR Fixed Lens
The Speco 2MP H.265 IP Dome Camera with IR and a 2.8mm fixed lens in white is a high-performance surveillance solution designed for both residential and commercial applications. This white dome camera captures crystal-clear 2-megapixel video at 30 frames per second, ensuring detailed monitoring of your premises. Equipped with H.265/H.264 compression technology, it efficiently manages bandwidth and storage without compromising image quality.
  • 2.8mm Fixed Camera: The 2.8mm fixed camera lens offers a wide 107° horizontal field of view, providing comprehensive coverage ideal for monitoring expansive areas.
  • Dome Camera with IR: This dome camera with IR capabilities features an infrared range of up to 98 feet, ensuring clear night vision even in complete darkness. The true day/night operation with an IR cut filter guarantees optimal performance in varying lighting conditions.
  • Weather and Vandal Resistant: Built to withstand harsh environments, the camera is IP67 compliant for weather resistance and IK10 rated for vandal resistance, making it suitable for both indoor and outdoor installations
  • Advanced Detection Features: The camera supports line crossing, region intrusion, and video blurring detection, enhancing security by alerting you to potential threats.
The white dome camera seamlessly blends with various architectural styles, providing discreet surveillance. Its 2.8mm fixed camera lens ensures wide-area monitoring, reducing the need for multiple cameras. The dome camera with IR functionality delivers reliable performance in low-light conditions, ensuring your property is protected around the clock.
Ideal for securing entrances, hallways, parking lots, and other critical areas, this camera can be easily integrated into existing security systems. Its built-in standard PoE simplifies installation by reducing the need for additional power cables.
Incorporating the Speco 2MP H.265 IP Dome Camera with IR and a 2.8mm fixed lens into your security setup ensures comprehensive coverage and peace of mind, knowing that your surveillance needs are met with advanced technology and durable design.
