Seco-Larm Enforcer Magnetic Contact, 3/8 In. Stubby Press-Fit, Quick-Connect, 3/4 In. Gap, White
Regular price $3.95
Regular price $3.95 Sale price
Shop Seco-Larm Enforcer Magnetic Contact, 3/8 In. Stubby Press-Fit, Quick-Connect, 3/4 In. Gap
The Seco-Larm Enforcer Magnetic Contact is designed for monitoring the status of doors, windows, and other entry points in residential and commercial properties. It is ideal for use in tight spaces where a low-profile security solution is required. This magnetic contact is particularly useful in security systems that require quick installation and reliable performance. Simply install the contact on a door or window frame and align the magnet with the contact when the door or window is closed. If the door or window is opened, the magnet moves away from the contact, triggering an alert or alarm in your security system.
Features:
  1. Stubby Press-Fit Design: The 3/8-inch stubby design ensures an easy and secure fit, especially in tight or concealed areas, making it a versatile choice for various installations.
  2. Quick-Connect Wiring: The quick-connect feature allows for fast and efficient wiring, reducing installation time and effort.
  3. 3/4-Inch Gap Coverage: This Enforcer Magnetic Contact can accommodate a 3/4-inch gap between the contact and magnet, providing reliable performance even in larger gaps.
  4. Durable Construction: Built to last, this seco-larm enforcer magnetic contact is made from high-quality materials, ensuring longevity and consistent performance.
  5. Discreet Appearance: The white finish allows the contact to blend seamlessly with most interiors, maintaining the aesthetic integrity of your space.
  6. Versatile Application: Suitable for both residential and commercial properties, this magnetic contact is ideal for monitoring doors, windows, and other entry points.
  7. Enhanced Security: Provides reliable monitoring of entry points, ensuring that any unauthorized access is promptly detected and reported by your security system.
Dimensions 1 x 7/16 x 3/8 inches
Gap 3/4 inches (18 mm)
Terminals Quick-connect
Circuit Closed
Listings UL
Shop Seco-Larm Enforcer Magnetic Contact Ezlo
Regular price $3.95
