The Philio Z Wad Temperature Humidity Sensor presence of moisture or water in your basement can lead to long-lasting problems, so catching it early is key. This Z-Wave 500 Series Flood, Temperature & Humidity Sensor will alert you to issues so you can solve them right away Z Wave temperature and humidity sensor and Z-Wave temperature sensor. This Flood sensor features an extra-long battery life, which means you can add it to your system and know it will keep you informed of what’s happening at home for years.
This philio flood sensor device supports OTA firmware upgrades so it will always be up-to-date with the latest technology, and also features AES 128-bit encryption for added security.CE/FCC/Z-Wave Plus certified Ezlo Secure controller.
