The On-Q/Legrand Trio Combo Module is the perfect solution for home or office networking needs. This module features 6x8 connectivity, with Cat5e data support, allowing you to easily connect all of your devices and peripherals. With its sleek design and easy installation, this module is perfect for upgrading your home or office network.
The On-Q/Legrand Trio Combo Module is designed to provide reliable and high-speed data transfer, ensuring that your network runs smoothly and efficiently. With its durable construction and reliable performance, this module is the ideal choice for any networking application. Upgrade your network today with the On-Q/Legrand Trio Combo Module.
Manufacturer Part #
CO1156
Color
White
Cable Type
Cat5e, Coaxial
Number of Ports
21
Material
ABS Plastic
Mounting
Enclosure
Operating Temperature
32°F to 122°F (0°C to 50°C)
Dimensions
6.4(W) x 6.7(H) x 3.5(D) inches (163 x 169 x 88 mm)
Certifications
RoHS
Manufacturer Part #
CO1156
Color
White
Cable Type
Cat5e, Coaxial
Number of Ports
21
Material
ABS Plastic
Mounting
Enclosure
Dimensions
