On-Q/Legrand In-Wall TV Power and Cable Management Kit, Pre-Wired
Regular price $98.95
Regular price $98.95 Sale price
Shop On-Q/Legrand In-Wall TV Power and Cable Management Kit, Pre-Wired
The On-Q/Legrand In-Wall TV Power and Cable Management Kit, Pre-Wired is the ultimate solution for anyone looking to create a clean, organized, and professional-looking entertainment space. This innovative in-wall TV power and cable management kit allows you to easily hide unsightly cords and cables, giving your living area a sleek, clutter-free appearance. The kit comes pre-wired and includes everything you need to securely mount your TV to the wall while keeping all your cables and power connections neatly concealed.
Designed with both functionality and aesthetics in mind, this TV Power and Cable Management Kit ensures that your home theater setup looks as good as it performs. The hide TV wires kit includes an in-wall power kit, a pre-wired cable management system, and a power inlet that connects your TV directly to an electrical outlet without visible wires. Whether you're setting up a new entertainment center or upgrading an existing one, this kit provides a seamless and straightforward installation process that results in a professional finish.
Features:
  1. Pre-Wired System: The in-wall TV power and cable management kit comes pre-wired, making installation quick and hassle-free.
  2. Comprehensive Kit: Includes an in-wall power kit, pre-wired cable management channels, and a power inlet for easy and concealed connections.
  3. Clutter-Free Setup: Designed to hide TV wires, this kit eliminates the need for exposed cords and cables, providing a clean and organized appearance.
  4. Secure Mounting: Ensures your TV is securely mounted to the wall, with all power and data connections neatly managed behind it.
  5. Universal Compatibility: Works with most TV brands and models, making it a versatile choice for any home theater setup.
  6. Simple Installation: Easy-to-follow instructions and all necessary components are included, making the installation process straightforward even for DIY enthusiasts.
Usage:
  • Home Theater Installations: Ideal for setting up a new TV or upgrading an existing home theater, providing a clean, professional look.
  • Living Room and Entertainment Areas: Perfect for hiding cables in any room where a wall-mounted TV is used, enhancing the room's overall aesthetics.
  • Commercial Spaces: Suitable for offices, conference rooms, or retail environments where a clean and organized TV setup is essential.
Benefits:
  • Professional Appearance: Achieve a sleek, modern look by concealing all power and data cables behind the wall, creating a clutter-free environment.
  • Enhanced Safety: By hiding wires and cables, the kit reduces the risk of tripping hazards and keeps cords away from children and pets.
  • Versatile Installation: Whether you’re mounting your TV above a fireplace or in a living room, this kit offers a flexible and easy-to-install solution that suits any space.
  • Increased Home Value: A clean, professionally installed entertainment center can enhance the aesthetic appeal of your home, potentially increasing its value.
Product Specs:
Manufacturer Part # CPT306W-V1
Color White
Amps 15A
Drywall Hole Size Top: 5.38"W x 7.13"H
Bottom: 2.25"W x 3.75"H
Material Plastic
Minimum Depth Requirement (US) 3.75"
Mounting Wall Mount
Storage Temperature 32°F to 122°F
Supported Standards NEMA 5-15R
Volts (AC) 125 VAC
Wire Gauge 14-2 AWG with Ground
In-Wall Rated Yes
Receptacle Type Decorator Receptacle
Number Of Outlets 2
Number of Ports 1
Installation Destination Indoor – Not intended for Fire-Rated walls
Mounting Points In-Wall
Mounting Hardware Included Yes
Cord Length 6 Feet
Dimensions 10.25 x 4.1 x 8.75 inches (261 x 104 x 222 mm)
Certifications ETL Listing No: Conforms to: UL STDs 514C & 498
ETL Listed: Yes
UL Listing No: UL514C and UL-498
Warranty 2 Years
