On-Q/Legrand 10x8 phone & Video Combo Module, 110 with RJ31X (1Ghz)
Regular price $79.99
Regular price $79.99 Sale price
The On-Q/Legrand 10x8 phone & Video Combo Module is the perfect solution for anyone looking to streamline their home or office communication systems. With 10 ports for phone connections and 8 ports for video connections, this module has everything you need to keep your communication lines running smoothly using On-Q/Legrand 10x8 phone & Video Combo Module. The module also features an RJ31X connection and can handle up to 1Ghz of bandwidth, ensuring that your calls and video streams remain crystal clear and uninterrupted.
Installation is a breeze, and the module is compatible with a wide range of phones and video devices, making it an ideal choice for any home or office setup. Whether you're looking to upgrade your existing communication systems or starting from scratch, the On-Q/Legrand 10x8 phone & Video Combo Module is the perfect choice for hassle-free communication. The specification of On-Q/Legrand 10x8 phone & Video Combo Module is below.
Manufacturer Part # CO1110
Type Telecom/Video Module
Material 18 Gauge Cold Rolled Steel
Color Black
Mounting Enclosure
Cable Type Cat5, Cat5e, Cat6, Coaxial
Receptacle Type IDC(10), F Connector(8), RJ31X(1)
Number of Receptacles 19
Ohm Value Splitter: Nominal impedance 75 Ohms
Surge Protected Splitter: Surge Withstand 6 kV Ring Wave Surge per IEEE C62.41 Category A3
Operating Temperature -40° to 140° F (-40° to 60° C)
Dimensions 6.0(W) x 5.0(H) x 3.1(L) inches (15.2 x 12.7 x 7.9 cm)
Weight 1.53 pounds
UL Standard Yes
UN SPS C 43222819
