Shop Nutone Smart Air Quality Wall Control Monitor
Introducing the Nutone Smart Air Quality Wall Control Monitor, the ultimate tool for monitoring and controlling the air quality in your home. This sleek and modern device offers easy-to-read digital displays of temperature, humidity, and air quality levels, allowing you to make informed decisions about your indoor environment.
Features and Benefits:
Comprehensive Monitoring: The smart air quality monitor provides real-time data on temperature, humidity, and air quality, ensuring you always know the status of your indoor environment.
Intuitive Touch Controls: With intuitive touch controls, you can easily adjust the settings of the Nutone Air Quality Control Monitor to optimize air quality for your comfort and health.
Alerts and Notifications: The air quality control monitor features alerts for when the air quality is poor or needs attention, giving you peace of mind that your family is breathing clean and healthy air.
Easy Installation: This device is easy to install and compatible with most HVAC systems, making it a seamless addition to your home.
Enhanced Air Quality: By monitoring and adjusting air quality levels, the Nutone Smart Air Quality Wall Control Monitor helps you create a healthier living environment.
User-Friendly Interface: The digital display is easy to read, and the touch controls make it simple to manage your air quality settings.
Proactive Alerts: Stay informed with alerts that notify you when air quality drops, allowing you to take action promptly.
Seamless Integration: Compatible with most HVAC systems, this smart air quality monitor integrates effortlessly into your home's existing setup.
Display: Digital readout of temperature, humidity, and air quality levels
Controls: Intuitive touch controls
Compatibility: Works with most HVAC systems
Installation: Easy wall-mounted installation
Upgrade your home's air quality control with the Nutone Air Quality Control Monitor. Ensure your family breathes clean, healthy air with this essential smart device.
Product Specs:
Manufacturer Part #:
BIAQWC100P
UPC:
026715265329
Smart Sensors:
Detect temperature, humidity, tVOC's, and eCO2
Inputs:
120V, 60 Hz
Outputs:
1/2 HP Motor, 15A Resistive, 15A Inductive, 3A Incandescent, 0.6A Electronic Ballast. When used in combination with fan/light fixtures that are switched together, the device is rated for the following lamps: 360W incandescent, 72W LED or 72W CFL. Typical wire sizes: 12AWG (MAX) or 14AWG solid copper wire rated for at least 90°C. For Control of Electronic Ballast, CFL's, LED and LED Lamps.
Connectivity:
Requires a 2.4 GHz Wi-Fi network within 100 feet
Compatibility:
Works with compatible Broan bath fans, Fresh Air Systems, and ADA-compliant range hoods. Can control light and fan independently.
Dimensions:
5.125 H x 2.25 W x 2.0625 D inches
Ratings and Certifications:
RoHS and Prop. 65 compliant, Pollution Degree 2 product for household environment
