Nutone Garage Door Controller
Regular price $24.99
Regular price $24.99 Sale price
The NuTone NGD00Z Garage Door Remote Controller Accessory opens or closes a sectional garage door remotely through a Z-Wave certified Gateway or Security Panel. It is compatible with virtually any automatic garage door opener connected to a sectional garage door. Installers only need to ‘pair’ the unit into the Gateway, mount the unit, connect two wires and plug it in. The NGD00Z provides both audible and visual warnings prior to remotely-activated door movement, allowing it to meet UL 325-2010 safety requirements. The NGD00Z ships with a wireless tilt sensor that attaches to the inside of the garage door, which reports ‘open’ or ‘closed’ status to the controller. Z-Wave Range: Up to 100 feet between the wireless controller and/or the closest Z-Wave receiver module. Includes 120VAC / 60Hz to 12VDC Power supply, Garage Door Tilt Sensor and Mounting Bracket and Hardware. NuTone’ s family of Z-Wave certified wireless lighting, security and control products bring a new level of intelligent wire-free capability to commercial and residential environments. The Z-Wave wireless protocol is an international wireless standard for remote home automation, security and other applications. Embedded in each device, the Z-Wave smart chip enables two-way RF communication among hundreds of Z-Wave enabled devices, allowing products and services from multiple manufacturers to work seamlessly. NuTone Z-Wave products are easy to install, and allow dealers to create an integrated wireless network with nearly limitless expansion and interoperability with security systems, entertainment, appliances, and more. All products operate at the standard 908.42 MHz frequency, supporting network wide inclusion and are security system compatible. All NuTone Z-Wave products integrate with other NuTone Z-Wave enabled products, and can also act as a wireless repeater to ensure that commands intended for another device in the network are received.
Nutone Garage Door Controller - Vera Shop
