Light Sensor T1 Brightness Sensor Zigbee 3.0 Smart Home Light Detector Magnetic Remote Control Home Homekit APP
Regular price $51.62
Regular price $0.00 $51.62 Sale price
Aqara Light Sensor T1 Brightness Sensor Zigbee 3.0 Smart home Light Detector Magnetic Remote Control Aqara Home Homekit APP
Notice
Aqara Light Sensor T1 is Zigbee 3.0 connection, must works with zigbee 3.0 gateway (such as Aqara hub E1, M1S, M2, P3, Camera gh2, G3 etc., and some open-source gateway.)
Main Features
● Using Texas Instruments component, the range can be switched intelligently based on the current ambient light.
● Highest sensitivity 1 lux, Higher measurement range 0-83k lux.
● The outer shell is made out of anti-UV material and protects the sensor from discoloration.
● The sensor is also energy efficient, and one battery can last over 2 years under normal usage.
● Can work with Apple HomeKit, google assistant and Alexa.
Product Model: GZCGQ11LM
Operating Temperature: -10 ℃℃~+50
Wireless Protocol: Zigbee 3.0
Operating Humidity: 0~95% RH, no condensation
Battery: CR2450
Scope of Test: 0~83000lux
Executive Standard: Q/QLML025
Detection accuracy: ±2% (calibrated according to ordinary
incandescent lamp at 2854K) & 5% (other visible light sources)
Battery Life: 2 years
Aqara Brightness Sensor T1
Intelligently perceive light changes
Intelligent linkage
Delicate and small
Convenient magnetic suction
Intelligently perceive light changes and brightness changes
Place light sensors beside windows, walls, doors, etc....
intelligently perceive light changes and light intensity,
and linkage control other Smart devices , make life more intelligent and comfortable
Good helper for protecting eyes
When you are reading in the living room or the child is studying in the study,
the light sensor sensitively senses that the light intensity becomes weak
and automatically turns on the light
Smart Housekeeper
When the sun shines into the room, the light sensor will close the curtain automatically,
Prevent sunlight damaging furniture or cosmetics
When the room light is strong,
the light sensor will turn off the bulb,
saving energy and environmental protection
Support zigbee 3.0
More security, higher compatibility, Complete automation ,
more stable network, low power consumption
Advanced Technology
Using texas instruments component,
the range can be switched intelligently based on the current ambient light ,
highest sensitivity 1lux,higher measurement range 0-83k lux ,
the outer shell is made out of anti-UV material and protects the sensor from discoloration .
the sensor is also energy efficient and one battery can last over 2 years under normal usage
