Expert Support Available 7 days/week
GoControl Best Smart Plug-In Dimmer Module
$37.95
Availability: In Stock
Buy Now
The PD300EMZ5-1 Best Smart Plug-in Lamp Module is designed to provide Z-Wave control to a connected dimmable lamp. The PD300EMZ5-1 module is plugged into any standard grounded AC wall outlet, and the lamp is then plugged into the module. Once connected, the lamp can be dimmed or turned on or off remotely via the Z-Wave controller. The Best Smart Plug module contains two power receptacles – one controlled, and one pass-through (powered at all times) via GoControl Plug-In.
The Best Smart Plug-in Lamp Module can also act as a wireless repeater to ensure that commands intended for another device in the network are received (useful when a device would otherwise be out of radio range).
Weight 1.0009 lbs
Shopping Cart
Scroll to Top
