Smart GoControl Plug In Appliance Module
Regular price $37.95
Regular price $37.95 Sale price
Shop Smart GoControl Plug In Appliance Module
The GoControl Plug In Appliance Module is designed to provide Z-Wave control to a connected load. The Smart Plug-in module is plugged into any standard grounded AC wall outlet, and the appliance or other device is then plugged into the module Ezlo Secure controller. This innovative device allows you to remotely control lamps, fans, electronics, and other appliances directly from your smartphone or tablet using a compatible Z-Wave hub (hub sold separately).
Unmatched Features and Advantages of Smart Plug In Appliance:
  • Manage your appliances from anywhere with an internet connection using your Z-Wave hub and smartphone app. No more rushing home to turn off a forgotten lamp or worrying about leaving something running.
  • Set up automated schedules to turn on lights at sunset, power off electronics after a certain time, or create custom routines for added convenience.
  • The Smart GoControl Plug In Appliance Module is incredibly easy to set up. Simply plug it into a standard AC wall outlet, then plug your appliance into the module. No electrician required.
  • The module features two convenient outlets. One is controlled, allowing you to turn it on or off remotely, while the other is a pass-through, providing continuous power for devices that need to stay on all the time.
  • This Plug In Appliance Module doubles as a Z-Wave repeater, helping to strengthen the signal within your Z-Wave network and ensure reliable communication between your hub and other Z-Wave devices, even if they're farther away.
  • Gain peace of mind by remotely checking the status of your connected appliances, ensuring they're turned off when they're not in use.
  • Schedule appliances to turn off automatically or create routines to reduce energy consumption and potentially lower your electricity bills.
