The Fortrezz Flood Sensor with Buzzer alerts you when it gets wet. Simply place it on the floor near water-using appliances and fixtures such as dishwashers, toilets, and washing machines. Water damage is caused by leaking pipes, corroded water heaters, leaky toilets, fixtures in bathrooms, laundry rooms with aging appliances, and more.
The Water Detector is a Z-Wave-enabled device and is fully compatible with any Z-Wave-enabled network.
