Transform your home audio system with the EISsound In-Wall Bluetooth Audio Receiver with Power Supply. This sleek and elegant device allows you to stream music wirelessly from your smartphone, tablet or laptop directly to your in-wall speakers. With its easy plug-and-play installation, you can enjoy high-quality sound with minimal fuss. The included power supply ensures that your audio receiver is always ready to go. The white finish blends seamlessly into any decor, making it a perfect addition to your home entertainment setup. Whether you're hosting a party or just relaxing at home, the EISsound In-Wall Bluetooth Audio Receiver with Power Supply delivers exceptional audio performance that you'll love. Get more home theater automation systems from Ezlo now!
Manufacturer Part #:
5280B
UPC:
8436031618792
Outputs:
Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance:
4/8/16 ohms
Speaker Output:
5W stereo max.
Other Connection:
Volume limitation and mono/stereo jumpers
LED Display:
Off: Disconnected and Audio Off
Bluetooth:
Blue Flashing – searching BT Device
Bluetooth:
Blue On – BT connected
Audio-In:
Red On – Audio-In Activated
Voltage Terminals VDC, GND:
Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth:
Minimum: 22mA Normal: 111Vdc
Consumption Demand Jack 3.5mm:
Minimum: 22mA Normal: 99Vdc
Input Signal Jack 3.5mm:
Normal: 100mVrms Maximum: 550mVrms
Input Signal Jack 3.5mm Input Impedance:
Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm:
Maximum: 5Wrms
Output Signal Output 8 ohm:
Maximum: 2.5Wrms
Output Signal Output 16 ohm:
Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4:
Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance:
Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4:
Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance:
