Chief THINSTALL Swing Arm Display Mount, 9.85 In. Extension, 10-32 In.
Regular price $109.60
Regular price $109.60 Sale price
Introducing the Chief THINSTALL Swing Arm Display Mount, 9.85 In. Extension, 10-32 In. the ultimate solution for mounting your display in a sleek and space-saving manner. With a 9.85-inch extension, this mount can hold displays ranging from 10 to 32 inches, making it a versatile option for a variety of settings Chief THINSTALL Swing Arm.
The swing arm design allows for easy adjustment and positioning of your display, ensuring optimal viewing angles for any situation. Additionally, the mount's slim profile and low-profile design means it can be mounted flush to the wall, maximizing available space.
Constructed with durable materials and engineered for easy installation, the Chief THINSTALL Swing Arm Display Mount is the perfect choice for anyone looking to elevate their display setup. Don't settle for a bulky and unattractive mount - choose the Chief THINSTALL and enjoy a sleek and seamless display experience.
Product Specs:
Certifications UL
Color Black
Maximum Extension 9.9 inches (251mm)
Minimum Depth 1.5 inches (38mm)
Mounting Pattern Compatibility (Universal Versions) 75 x 75, 100 x 100, 200 x 100, 200 x 200mm
Orientation Landscape, Portrait
Overall Dimensions 9.3(H) x 14(W) x 1.5(D) inches (237 x 356 x 38mm)
Pivot ±90 degrees (depending on screen width)
Post-Installation Leveling (Roll) Yes
Weight 6.3 pounds
Solution Type Universal
Tilt +0 degrees, -12 degrees
Typical Screen Sizes 10 to 32 inches
Wall Stud Compatibility Single Stud
Weight Capacity 35 pounds (15.9kg)
Shop Chief THINSTALL Swing Arm Display Mount Ezlo
