Chief THINSTALL Swing Arm Display Mount, 25 In. Extension, 26-52 In.
Regular price $455.20
Regular price $455.20 Sale price
Experience the ultimate display flexibility with the Chief THINSTALL Swing Arm Display Mount. This innovative mount offers an impressive 25-inch extension, allowing you to easily adjust your display to the perfect viewing angle. Designed to accommodate displays ranging from 26 to 52 inches in size, this versatile mount is perfect for any home or office setting. Its sleek and stylish design is sure to complement any decor, while its durable construction ensures a secure and stable display. So why settle for a fixed display when you can enjoy the freedom and flexibility of the Chief THINSTALL Swing Arm Display Mount?
Product Specs:
Certifications UL
Color Black
Manual Height Adjustment 1
Maximum Extension 25.7 inches (652.8mm)
Maximum Screen Thickness 5 inches (127mm)
Minimum Depth 1.8 inches (46mm)
Mounting Pattern Compatibility (Universal Versions) 100 x 100mm – 600 x 400mm
Orientation Landscape
Overall Dimensions 17.2(H) x 29.5(W) x 1.8(D) inches (437 x 749 x 46mm)
Pivot ±90 degrees (depending on screen width)
Post-Installation Leveling (Roll) Yes
Weight 31.3 pounds
Solution Type Universal
Tilt -15 degrees
Typical Screen Sizes 26 to 52 inches
Wall Stud Compatibility 16 inches
Weight Capacity 75 pounds (34kg)
