Chief THINSTALL Dual Swing Arm Wall Display Mount, 26-52 In.
(5.00)5 Reviews
Out of Stock
$399.20
SKU: CMTS318TU
Brands:
Introducing the Chief THINSTALL Dual Swing Arm Wall Display Mount, the perfect solution for mounting your TV or display screen securely and stylishly. This mount is designed to hold screens ranging from 26-52 inches in size, making it ideal for a variety of applications, from home theaters to conference rooms.
With its sleek, low-profile design, the Chief THINSTALL mount is perfect for mounting your TV or display screen in tight spaces, while still providing easy access to all of your connections and controls. The dual swing arm design allows you to easily adjust the angle and position of your screen, while the built-in cable management system keeps all of your cables neat and organized.
Constructed from high-quality materials, the Chief THINSTALL mount is built to last. It is backed by a lifetime warranty, so you can be confident in your purchase. Whether you’re mounting a TV in your living room or a display screen in your office, the Chief THINSTALL Dual Swing Arm Wall Display Mount is the perfect choice for a secure, stylish, and versatile mounting solution.
Product Specs:
Certifications UL Listed
Color Black
Lateral Shift 16 inches (406.4mm)
Manual Height Adjustment 1 inch (25mm)
Max. Extension 18.2 inches (462.3 mm)
Max. Screen Thickness 5 inches (127mm)
Min. Depth 1.8 inches (46 mm)
Mounting Pattern Compatibility (Universal Versions) 100 x 100mm – 600 x 400mm
Orientation Landscape
Dimensions 17.2(H) x 22.6(W) x 1.8(D) inches (437 x 574 x 46 mm)
Pivot (numerical value) ±90° (depending on screen width)
Post-Installation Leveling (Roll) Yes
Solution Type Universal
Tilt + 0° , – 15°
Typical Screen Sizes 26 – 52 inches
Wall Stud Compatibility (inches) 16
Weight Capacity 75 pounds (34 kg)
Customers Reviews
(5)
  1. Richard (verified owner)
    Very fast delivery.
    1 product
  2. Alan (verified owner)
    Good service.
    1 product
  3. Zohar (verified owner)
    Good service.
    1 product
  4. Phoenix (verified owner)
    Good service.
    1 product
  5. Dominic (verified owner)
    The product is firmly packed.
    1 product
Back to Top
chatsimple
