Chief THINSTALL Dual Swing Arm Wall Display Mount, 26-47 In., Single Stud
Regular price $260.80
Regular price $260.80 Sale price
The Chief THINSTALL Dual Swing Arm Wall Display Mount is the perfect solution for those looking to mount their TV or monitor with ease. Designed to accommodate screens ranging from 26-47 inches in size, this mount features a single stud installation for added convenience. The dual swing arm design allows for easy adjustment and positioning, making finding the perfect viewing angle chief thinstall easy. With a sleek and modern design, this mount is functional and stylish, making it an ideal addition to any home or office thinstall. Plus, its durable construction ensures that your display will remain securely in place for years to come. Don't settle for a subpar display mount - upgrade to the Chief THINSTALL Dual Swing Arm Wall Display Mount today!
Product Specs:
Certifications UL Listed
Color Black
Manual Height Adjustment 1 inch (25mm)
Max. Extension 18 inches (456 mm)
Max. Screen Thickness 5 inches (127mm)
Min. Depth 1.5 inches (38 mm)
Mounting Pattern Compatibility (Universal Versions) 100 x 100, 200 x 100, 200 x 200, 300 x 200, 300 x 300, 400 x 200 and 400 x 400mm
Orientation Landscape, Portrait
Dimensions 14(H) x 13(W) x 1.5(D) inches (356 x 330 x 38 mm)
Pivot (numerical value) ±90° (depending on screen width)
Post-Installation Leveling (Roll) Yes
Weight 13 pounds
Solution Type Universal
Tilt + 0° , – 12°
Typical Screen Sizes 26 – 47 inches
Wall Stud Compatibility (inches) Single Stud
Weight Capacity 75 pounds (34 kg)
Shop Chief THINSTALL Dual Swing Arm Wall Display Mount Ezlo
