The Applied Digital ADICON 2500 SECU-16IR IR I/O Module is the perfect addition to your security system. This module allows you to easily monitor and control 16 infrared devices, such as motion sensors and cameras, with ease. The compact design makes it easy to install and integrate into your existing system. With its reliable and high-quality performance, you can be sure that your security system is always up and running, providing you with peace of mind. The ADICON 2500 SECU-16IR IR I/O Module is the ideal solution for your security needs.
I/O:
16 switched zones IR Output (accepts standard IR emitter)
