Applied Digital ADICON 2500 SECU-16 I/O Module
Regular price $120.95
Regular price $120.95 Sale price
The Applied Digital ADICON 2500 SECU-16 I/O Module is a versatile and reliable input/output device designed for a wide range of industrial automation applications. With 16 digital inputs and 16 digital outputs, this module provides a flexible interface between sensors, switches, and other control devices and your automation system. The module features advanced signal conditioning and isolation to ensure accurate and reliable data transmission, even in harsh industrial environments. Its compact and modular design makes installation and maintenance quick and easy, while its high-speed communication capabilities enable fast and efficient data transfer. Whether you're looking to optimize your manufacturing processes, improve your plant's efficiency, or enhance your control system's performance, the Applied Digital ADICON 2500 SECU-16 I/O Module is the perfect solution for your automation needs.
I/O: 8 Relay Outputs – Screw Terminals (Form A 0.5A); 8 Input Channels – Screw Terminals (1K Shunt or 0-5V 8-bit Analog)
ADNET: 2 Screw Terminals (up to 14 AWG)
Power: 2 Screw Terminals (up to 14 AWG)
Size: 5.5(L) x 3.25(W) x 1.38(H) inches
Power: 9-16 Volts AC or DC, 200 mA
