Aeotec Zigbee Multipurpose Sensor
Regular price $35.95
Regular price $35.95 Sale price
Aeotec Zigbee Smart Multipurpose Sensor
The Aeotec Zigbee Multipurpose Sensor is a versatile and intelligent device designed to elevate your smart home experience. This compact zigbee multi sensor is capable of detecting motion, temperature, and light level changes, making it a powerful addition to your home security and automation systems. With its discreet design, the sensor can be easily installed on doors, windows, or walls, where it monitors environmental conditions and triggers connected smart devices accordingly.
Benefits:
  • Versatility: As a true multipurpose sensor, it not only detects movement but also monitors temperature and light levels, providing comprehensive coverage for your home.
  • Enhanced Security: By detecting any motion, this zigbee multi sensor ensures that you’re immediately alerted to any potential intrusions, bolstering your home’s security.
  • Smart Automation: The sensor can be integrated into your smart home system to trigger actions, such as turning on lights when motion is detected or adjusting thermostats based on temperature changes.
Usage:
The Aeotec Zigbee Multipurpose Sensor is perfect for homeowners seeking to enhance both security and automation. Whether you're monitoring entry points or automating your lighting and climate control, this Zigbee Multipurpose Sensor delivers reliable performance across various applications.
How It Works:
This zigbee multi sensor connects wirelessly to Zigbee-enabled hubs like SmartThings, Echo Plus, and Hubitat. Once installed, it continuously monitors its surroundings for motion, temperature fluctuations, and changes in light levels. When a predefined condition is met, such as detecting motion or a significant change in temperature, the sensor communicates with your smart hub, triggering appropriate actions or sending alerts to your devices.
Compatibility:
The Aeotec Zigbee Multipurpose Sensor is designed for seamless integration with a variety of Zigbee-enabled hubs, including SmartThings, Echo Plus, and Hubitat. Its easy installation process allows you to quickly set it up and start monitoring your home without the need for complex wiring.
Aeotec Zigbee Multi-Purpose Sensor - Motion & Environmental Sensor
