2GIG 345 MHz Tilt Sensor, Stay informed about the status of doors or objects that open/close with the 2GIG 345 MHz Tilt Sensor operating at 345 MHz. This sensor, which functions wirelessly and runs on batteries, is designed to detect its angular position, specifically when mounted at a 45-degree angle. Movement altering the sensor's position triggers it to dispatch a notification, keeping you updated about any status changes. Additionally, the sensor is programmed to issue warnings if its cover is tampered with or if the battery level drops to a critical low.
Key features include:
Alerting upon changes in its orientation, cover removal, or low battery.
Operates on a 345 MHz frequency band.
Compatible with GC2 firmware versions starting from 1.14 onwards.
