WaterCop Classic Outdoor Kit, Indoor Control Unit with 25 Ft. Cable and Outdoor Actuator
0 Reviews
In Stock
$378.25
SKU: DQWCDACT25W
The WaterCop Classic Outdoor Kit is the perfect solution to protect your home from water damage caused by leaks or flooding. This kit includes an indoor control unit with a 25 ft. cable and an outdoor actuator. The system works by detecting water leaks and automatically shutting off the main water supply, preventing any further damage to your home. The outdoor actuator is designed to be installed on the main water supply line outside your home, making it easy to access and control. The indoor control unit provides real-time alerts and status updates, allowing you to monitor the system remotely. With this kit, you can have peace of mind knowing that your home is protected from water damage, even when you’re not there to monitor it. The WaterCop Classic Outdoor Kit is easy to install and comes with everything you need to get started. Protect your home today with the WaterCop Classic Outdoor Kit.
Customers Reviews
There are no reviews yet.
Back to Top
chatsimple
