Shop SONOFF TH Origin With The Ultimate Smart Home Controller for Temperature & Humidity
The SONOFF TH Origin is an advanced Smart Home Controller designed to monitor and manage temperature and humidity levels in real time. Building upon the legacy of its predecessors, the TH10 and TH16, this upgraded version boasts enhanced capabilities, making it an essential component for modern smart homes.
- High Power Capacity: Supports up to 20A Max Output, ensuring compatibility with a broader range of home appliances.
- Comprehensive Monitoring: Equipped with a humidity monitor sensor, it provides accurate readings, allowing users to maintain optimal environmental conditions.
- Historical Data Access: Access up to six months of temperature and humidity data, detailed down to the hour, facilitating informed decisions about your environment.
- Local Automatic Control: With LAN support, the device can autonomously toggle connected appliances based on predefined temperature and humidity thresholds, even without internet access.
- Voice Integration: Seamlessly integrates with Amazon Alexa and Google Assistant, enabling hands-free control and status inquiries.
Usage Scenarios
- Greenhouse Management: Maintain optimal conditions for plant growth by monitoring and adjusting humidity and temperature levels.
- Reptile Terrariums: Ensure a stable habitat for reptiles by keeping environmental parameters within desired ranges.
- Home Brewing: Monitor fermentation environments to produce high-quality brews.
- Energy Efficiency: Automate appliance control based on environmental conditions, leading to potential energy savings.
- Enhanced Comfort: Maintain ideal indoor conditions, promoting well-being and comfort.
- Data-Driven Decisions: Utilize historical data to optimize appliance usage and environmental settings.
Technical Specifications
- Model: THR320
- Input/Output: 100-240V~ 50/60Hz 20A Max
- Wi-Fi: IEEE 802.11 b/g/n 2.4GHz
- Operating Temperature: -10°C~40°C (14℉~104℉)
- Supported Sensors: THS01, DS18B20, MS01
- Dimensions: 98x54x27.5mm
Incorporating the SONOFF TH Origin into your smart home setup ensures precise environmental monitoring and control, enhancing both comfort and efficiency. Its robust features and compatibility with various sensors make it a versatile choice for diverse applications.
There are no reviews yet.
