SONOFF TH Elite 16A/20A WiFi Smart Switch Temperature and Humidity Monitoring Switch Smart Home work with DS18B20/ Si7021/ RL560
0 Reviews
In Stock
$33.98
Buy now
SKU: 3256804200004743
Brands:
Shop SONOFF TH Elite Temperature Humidity Monitoring Switch
The SONOFF TH Elite is a versatile Temperature Humidity Control Switch designed for smart home automation. This device not only controls high-power appliances like geysers and heating systems but also provides precise real-time monitoring of environmental conditions through compatible sensors. With advanced features such as support for up to 20A loads, integration with voice assistants, and historical data logging, the TH Elite ensures you maintain optimal comfort and energy efficiency in your home.
The SONOFF TH Elite is a 20A WiFi Smart Switch equipped with advanced temperature and humidity monitoring capabilities. It works seamlessly with sensors like the DS18B20, Si7021, and RL560, enabling accurate tracking of ambient conditions. The device displays real-time data on an LCD screen, refreshing every 5 seconds, ensuring that your home environment is always under control.
  1. High Power Capacity: Supports devices up to 20A, ideal for electric heating systems or geysers under 3kW.
  2. Smart Scenes and Automation: Automate triggers based on preset thresholds for temperature or humidity to control connected devices.
  3. Historical Data Management: Store up to 6 months of temperature and humidity records, exportable in .xlsx format.
  4. LAN and Wi-Fi Control: Enjoy uninterrupted control, even when offline, via local automation.
  5. Voice Control Compatibility: Supports Alexa, Google Assistant, and eWeLink, allowing easy voice-based monitoring and control.
The TH Elite excels as a Temperature Humidity Monitoring Switch, helping you maintain stable conditions for various applications, such as plant care, aquarium maintenance, and room climate control. You can extend sensor connectivity with the RL560 cable, making it perfect for larger setups like greenhouses.
By enabling remote control through mobile apps and platforms like Home Assistant, this switch also promotes energy savings. For example, automating heating appliances based on temperature thresholds minimizes unnecessary energy use, helping users cut costs. Furthermore, push notifications ensure you are alerted immediately if environmental conditions cross your set limits.
Customers Reviews
There are no reviews yet.
Back to Top
chatsimple
