Smart Life App WiFi Energy Meter AC 110V 230V 100A KWh Power Monitor Electricity Statistics Tasmota ESPHome For Home Assistant
0 Reviews
In Stock
$6.89$24
SKU: 3256806487321401
Brands:
Shop Smart Life App WiFi Energy Meter Power Monitor Electricity Statistics
Introducing the Smart Life App WiFi Energy Meter, a versatile device designed to monitor and manage your home’s energy consumption efficiently. Operating within a voltage range of 110V to 230V and supporting up to 100A, this energy meter provides real-time data on your electrical usage. Compatible with Tasmota and ESPHome firmware, it seamlessly integrates with Home Assistant, offering a comprehensive solution for smart home enthusiasts.
The Smart Life App WiFi Energy Meter is an advanced tool that empowers homeowners to track their energy consumption accurately. By connecting to your WiFi network, this device delivers real-time statistics on voltage, current, power, and cumulative energy usage directly to your smartphone or Home Assistant dashboard. Its compatibility with Tasmota and ESPHome firmware ensures flexibility and customization to suit various smart home setups.
  • Wide Voltage Range: Supports AC 110V to 230V, accommodating various household electrical systems.
  • High Current Capacity: Handles up to 100A, making it suitable for monitoring substantial electrical loads.
  • Real-Time Monitoring: Provides instantaneous readings of voltage, current, power, and energy consumption.
  • Firmware Compatibility: Works seamlessly with Tasmota and ESPHome, allowing for extensive customization and integration with Home Assistant.
  • Smartphone Integration: Utilizes the Smart Life App for easy access to energy statistics and device management
Installing the WiFi Energy Meter enables homeowners to gain insights into their energy consumption patterns, identify high-usage appliances, and implement energy-saving strategies. By leveraging real-time data, users can make informed decisions to reduce electricity costs and enhance the efficiency of their household systems. The device’s integration with Home Assistant allows for the creation of automation routines, such as turning off devices during peak usage times or alerting users to unusual energy consumption, thereby promoting a more sustainable and cost-effective home environment.
Incorporating the Energy Meter into your smart home setup not only provides detailed energy analytics but also contributes to a more efficient and environmentally friendly household. With its robust features and seamless integration capabilities, the Power Monitor stands as an essential tool for modern energy management.
Parameter
Min.
Regular
Max.
Unit
Voltage
80
260
V
Power
Consumption
50
100
300
mA
Current
0.02
100
A
Active
Power
2
26000
W
Frequency
45
50/60
65
Hz
Power
Factor
0
1
Energy
Consumption
0
999999
kWh
Voltage
Accuracy
±1
Current
Accuracy
±1
Energy
Accuracy
±1
Environment
Temperature
-10
23
60
Weight
90
g
Appearance
Size
78*34*65
mm
Hole
Size
35mm din
rail
mm
More details is coming very soon, please pay attention to our store!
Back to Top
chatsimple
