Speco Line Level Microphone for Cameras
Regular price $13.95
Regular price $13.95 Sale price
Shop Speco Line Level Microphone Camera
The Speco Line Level Microphone for Cameras is a high-sensitivity, omnidirectional condenser microphone designed to enhance your surveillance system by capturing clear audio. Its unique line-level output allows for easy integration with various devices, ensuring flexibility and compatibility across different setups. Whether you're aiming to add audio recording capabilities to your existing camera system or seeking a reliable microphone for new installations, this product offers a practical solution for diverse surveillance needs.
The Speco Line Level Microphone is engineered to provide high-quality audio capture for surveillance applications. Its line level microphone design ensures compatibility with a wide range of devices, including amplifiers and DVRs, without the need for additional adapters. This feature is particularly beneficial for systems with limited microphone inputs or those lacking dedicated microphone connections.
  • High Sensitivity: Designed to capture clear and detailed audio, enhancing the effectiveness of your surveillance system.
  • Omnidirectional Pickup Pattern: Ensures comprehensive audio coverage from all directions, ideal for monitoring areas with multiple sound sources.
  • Line Level Output: Allows direct connection to line-level inputs on amplifiers or DVRs, simplifying installation and reducing the need for additional equipment.
  • Compact Design: Facilitates easy integration into various surveillance setups without occupying significant space.
  • 12VDC Operation: Operates on 12VDC power, making it compatible with standard surveillance power supplies.
Ideal for enhancing surveillance systems, the Speco Camera Microphone is suitable for recording audio in various environments, including residential, commercial, and industrial settings. As a high-quality microphone camera, it seamlessly integrates with your existing security setup, ensuring reliable audio capture for your surveillance needs. Its easy installation process and compatibility with existing equipment make it a valuable addition to any security system
  • Enhanced Surveillance: Provides clear audio recordings, improving the overall effectiveness of your security system.
  • Flexibility: The line level microphone design ensures compatibility with a wide range of devices, offering versatility in system configurations.
  • Ease of Installation: The compact design and straightforward connectivity options facilitate quick and hassle-free setup.
  • Cost-Effective Solution: Offers a reliable audio recording solution without the need for additional adapters or equipment.
Incorporating the Speco Line Level Microphone into your surveillance system enhances audio recording capabilities, providing a comprehensive security solution.
Manufacturer Part #: CAMMIC
Type: Condenser
Weight: 0.1 lbs
Cable Length: 1.5 feet
Impedance: 10K Ohms
Sensitivity: -62dB ±3dB
Vcc: 1.5k Ohms
Frequency Range: 20Hz ~ 16kHz
Directivity: Omni-directional
Audio Output: Max 2Vp-p
Power Consumption: 10mA
Warranty: 2 Years
