Shop Qubino Z-Wave Mini Dimmer With Save Energy and Control Brightness
The Qubino Z-Wave Mini Dimmer is a compact and versatile device designed to enhance your home’s lighting control. As the smallest wireless dimmer available, it offers seamless integration into your existing Z-Wave smart home system, allowing you to remotely control and adjust the brightness of various dimmable bulbs.
- Universal Compatibility: The Qubino Smart Dimmer is compatible with all types of dimmable bulbs, including incandescent, halogen, LED, LED strips, and CFLs. It calibrates to work with your specific bulb type, ensuring optimal dimming performance.
- Flexible Installation: Designed for both 2-wire and 3-wire systems, the Qubino Z-Wave Mini Dimmer can be installed without a neutral wire, making it suitable for a wide range of electrical setups. Its compact size allows it to fit into even the smallest and most crowded electrical boxes.
- Energy Monitoring: The dimmer provides power monitoring capabilities, allowing you to track energy consumption and make informed decisions to reduce electricity usage.
- Advanced Protection: Equipped with built-in protection against overloads and overheating, the Qubino Smart Dimmer ensures safe operation and longevity.
- Easy Integration: With Smart Start functionality, the dimmer can be quickly added to your Z-Wave network, simplifying the setup process.
- Remote Control: Adjust your lighting from anywhere using your smartphone or compatible Z-Wave controller, providing convenience and flexibility.
- Mood Setting: Create the perfect ambiance for any occasion by dimming your lights to the desired level, enhancing the atmosphere of your home.
- Energy Efficiency: Monitor and manage your energy consumption effectively, leading to potential cost savings on your electricity bill.
- Safety and Security: Simulate your presence at home by scheduling lights to turn on and off, deterring potential intruders when you’re away.
Technical Specifications
- Power Supply: 110 – 240 VAC ±10% 50/60Hz
- Rated Load Current: 0.85A / 240 V AC
- Output Circuit Power: 200W / 240 V AC (resistive load)
- Power Monitoring Accuracy: ± 10% (2-wire), ± 2% (3-wire)
- Operating Temperature: -10 ~ +40°C (14 ~ 104°F)
- Dimensions: 38mm x 33.5mm x 15.5mm
- Weight: 24 g
- Electricity Consumption: 0.4 W
- Installation Requirements: For installation in boxes: Ø ≥ 60 mm or depth ≥ 60 mm
There are no reviews yet.
