Qubino Z-Wave Flush Dimmer 0-10V
0 Reviews
Out of Stock
$65.16
SKU: QUZMNHVD3
Brands:
Shop Qubino Z-Wave Flush Dimmer 0-10V With Effortless Lighting Control
The Qubino Z-Wave Flush Dimmer 0-10V is a versatile and compact device designed to integrate seamlessly into your smart home system, providing precise control over your lighting and other connected devices. By connecting this dimmer between your LED driver (0-10V) and the light switch, you can wirelessly manage your lighting through your smartphone or Z-Wave-enabled controller.
  • Universal Compatibility: The Qubino Flush Dimmer supports a wide range of LED lights and is compatible with various switch types, including push-button (momentary), on/off toggle switches, and potentiometers.
  • Energy Efficiency: With a low electricity consumption of just 0.5 W, this dimmer helps reduce energy costs while providing optimal performance.
  • Advanced Z-Wave Plus Technology: Equipped with Z-Wave Plus certification, the dimmer offers enhanced features such as faster operation, better wireless range, and improved noise immunity.
Installing the Qubino 10V dimmer is straightforward:
  1. Place the dimmer module between your LED driver (0-10V) and the existing light switch.
  2. Configure the device through your Z-Wave gateway or smartphone application.
  3. Enjoy the convenience of dimming or brightening your lights wirelessly, creating the perfect ambiance for any occasion.
Beyond lighting control, the dimmer’s 0-10V input can be paired with compatible digital sensors, allowing for responsive automation scenes. For instance, you can set your lights to adjust based on ambient light levels or schedule them to turn on/off at specific times.
Incorporating the Qubino Z-Wave Flush Dimmer 0-10V into your smart home enhances comfort, convenience, and energy efficiency, making it an ideal choice for modern living.
Customers Reviews
There are no reviews yet.
• Datasheet Pdf
Back to Top
chatsimple
