The Platinum Tools 15001 V-Notch Adjustable Wire Stripper is the perfect tool for any electrical project. This high-quality wire stripper is designed with a V-notch blade that allows for precise and clean stripping of wires without causing any damage. The adjustable dial on the tool allows you to easily adjust the blade depth to strip wires of varying sizes. The ergonomic grip is comfortable to hold and provides excellent control for accurate stripping. Made from durable materials, this wire stripper is built to last and will provide reliable service for years to come. Whether you’re a professional electrician or a DIY enthusiast, the Platinum Tools 15001 V-Notch Adjustable Wire Stripper is an essential tool for any electrical project.
Product Specs:
Body Material | #45C carbon steel |
Finish | Black oxide coating |
Hardness | HRC 44-46 |
Weight | 2.4 ounces |
Dimensions | 5-1/4 x 2-5/16 inches |
Bryan (verified owner) –
Good service.
David (verified owner) –
Good quality.
Patrick (verified owner) –
Very fast delivery.
Charles (verified owner) –
The product is firmly packed.
Isaac (verified owner) –
Very fast delivery.
