The Philio Smoke Sensor PSG01 is designed to give early warning of developing fires by giving off the alarm sounds from its build-in alarm horn. Easy to install with integrated ceiling bracket. Higher output power enhances communication range. Low power consumption. Automatic low battery reports. Over-the-air firmware upgrades.
NOTE: Not rated for outdoor use. IMPORTANT: MAY NOT MEET YOUR STATE’S STANDARDS FOR SMOKE ALARMS. CHECK YOUR LOCAL REQUIREMENTS BEFORE PURCHASE. (THIS MODEL DOES NOT SUPPORT HARDWIRING OR SPECIALIZED BATTERY PACKS.)
Daniel (verified owner) –
The product is firmly packed.
