Philio Smart Dimmer Plug EU
(5.00)1 Review
Out of Stock
$25.20
The Dimmer Plug is designed to control the on/off status of lighting in your house. The unit also provides dimmer function which is only applicable to light bulbs. At 220-240V voltage, this Dimmer Plug can support connected load of Max. 200W. To manually switch on the light, press and release the On/Off dimmer button when the light is off. The light will dim from off to the level which was set before switch off. To manually switch off the light, press and release the On/Off button shortly when the light is on. To adjust the dim level, press and hold the On/Off button until the desired dim level is achieved, then release.
Additional information
Weight 1.0009 lbs
Customers Reviews
(1)
  1. Mateo (verified owner)
    Good quality.
    1 product
• Datasheet Pdf
Back to Top
chatsimple
