Optex CHeKT 30W IP Horn Outdoor Speaker
(5.00)5 Reviews
Out of Stock
$564.95
SKU: OPCKIPS30W
Brands:
The Optex CHeKT 30W IP Horn Outdoor Speaker is a powerful and reliable audio solution for outdoor spaces. With its weather-resistant design and high-quality sound output, this speaker is ideal for use in parks, stadiums, and other outdoor venues.
Featuring a 30W power rating and a durable IP horn design, this speaker delivers clear, powerful audio that can be heard over long distances. It also includes a built-in amplifier and a range of advanced audio features, such as tone control, volume adjustment, and automatic gain control.
Whether you’re hosting a concert, leading a sports event, or just need to amplify your voice for a large crowd, the Optex CHeKT 30W IP Horn Outdoor Speaker is the perfect choice. So why wait? Order yours today and experience the power and clarity of this exceptional audio solution!
Manufacturer Part # CKIPS30W
Codec OPUS 48 kHz, MP3 44.1 kHz, G.722 ADPCM 16 kHz, G.711 PCMU 8 kHz, G.711 PCMA 8 kHz
Max SPL 120dB
Frequency Response 350Hz to 8KHz
Frequency Range 500-2KHZ ± 10dB, 400-12KHZ ± 20dB
Harmonic Distortion 0.1@1kHz
Signal to Noise Ratio 91dB
Security Password protection, IP address filtering, Digest authentication, User access log, firewall
Network Protocol SIP, ONVIF, HTTP, IPv4, DHCP, RTSP, RTP, RTCP, TCP, UDP, ARP, FTP, TFTP, NFS, NTP
Network Interface 10/100 Base-TX, RJ45
VoIP Support for SIP protocol for integration with VoIP systems, integrated with SIP/PBX. 2 SIP Accounts, SIP Direct IP Call, RTP Multicast
Amplifier Description Built-in 30W Amplifier
Alarm Output 1ch, When receiving a switch alarm, it can play a ringtone or a custom sound
Operating Temperature -30°C to +60°C
Operating Humidity 5% to 85%
Material ABS (IP67 water-proof)
Rate Power 30W
Power Supply POE or DC12V~24V
Installation Wall mounted
Dimensions 11 x 8 x 8 inches (285 x 205 x 290 mm)
Net Weight 4.4lbs. (2 KG)
Languages English
Warranty 2 Year
Customers Reviews
(5)
  1. Mason (verified owner)
    Good service.
    1 product
  2. Kaden Arabic (verified owner)
    Good quality.
    1 product
  3. Phoenix (verified owner)
    Good service.
    1 product
  4. Angel (verified owner)
    Good service.
    1 product
  5. Julian (verified owner)
    Good service.
    1 product
Back to Top
chatsimple
